Is it the esc
Old 08-05-2021 | 11:44 AM
Default Is it the esc
I have a hobby wing 10bl120 brushless esc with a surpass 4370kv motor it worked great. I recently had to do some work on the car and when I put it back together the motor barely turns and the wires and motor get really hot after only a minute of trying to get it to work any ideas on what's wrong?
Dougmag86 is offline
Old 08-05-2021 | 11:56 AM
the rc guy's Avatar
check drive line make sure its not binding. then check all solder joints wont hurt to change sensor cable. what did you do could you have caused this?
the rc guy is offline
Old 08-05-2021 | 12:21 PM
Don't know if you re-soldered the motor wires but check to see that there's no solder/wire touching between the a-b-c terminals. Creates quite the drag. Remove the pinion and make sure drive train is moving freely.
Andy Koback is offline
Old 08-05-2021 | 02:09 PM
Make sure there's no washers/screws jammed in your motor. Make sure ESC wires are soldered correctly (orientation) and cleanly. Make sure the car drivetrain spins freely when the pinion gear is removed.
xjwolfpacker is offline
Old 08-06-2021 | 08:12 AM
Check all your bearings (wheel) as well. I just had this same issue.
Sinister94 is offline
Old 08-07-2021 | 08:05 AM
Another idea, is it 4wd and you put one of the diffs in backwards?
HwyStar is offline
