Schumacher Cougar LD2 (2021) Thread
#76
Is anyone still driving the LD2?
I will be picking up a new 2wd kit soon, and my shop supports Schu and AE. Trying to decided between them, but figure for my skills (low) it probably won't matter which I pick. Leaning towards the Schu just because I lusted hard for a Top Cat back XX years ago as a teen, but never got one... Bad logic, but... LOL Also my buddy just got a LD2, so If I run one, we can share tuning tips... But AE just dropped the 6.4, so "New hotness" has an appeal too.
Either brand, I will be looking at a stock spec car, 21.5 class, small carpet track. The LHS guy says to get the LD2 because it is a lot lighter, which will help in a 21.5 class - but then I will need to add weights to get it up to minimum weight, so does that really matter?
Thoughts or advice? Any good reason to get one over the other?
#78
#79
I also haven’t broken any parts on my 6.3. Ran them both at the same tracks for about the same time (8 months). I do crash my fair amount.
I feel my LD2SS is better suited for Astro and B6.3 was better on black carpet.
#80
I have 2 Ld2 I’m about to list loaded and a loaded storm message me for details. Tons of spares also
#81
#83
#84
#85
#86
Well done. What benefits have you had from turning the shocks on the 4wd? and how did you do at the front since the shock absorber caps cannot be mounted in the arms
#87
#88
What is the benefit of running the front arms backwards? I’ve seen a few setups suggesting it. What is the benefit?
#89
Changes the front wheelbase, switching them moves the hub carrier rearward 1.5mm. This gives more traction at the expense of stability in rougher sections.
#90
Looking for LD2 Stock Spec
Any know where I could fin a stock spec kit? New or used
