Motor Question
Motor Question
I need to replace this motor with something better for a custom project:
Google:
rs 380 ph pdf
(can't post links yet)
Is this motor a standard RC size?
Can I walk into any hobby shop and find a direct swap with better performance?
Can I go brushless. Non serviceable brushed motors are pretty much retarded in this day and age.
Google:
rs 380 ph pdf
the "380" size motor is common in 1/14, 1/16, and 1/18 scale RC cars. Hobby shops should have some on the shelf. There are plenty of brushless motors in this size, but you need an ESC that is compatable with brushless (most brushed esc's have a red and black wire to the motor, brushless RC motors have 3 motor wires. You need all 3 brushless wires connected properly for the motor to work as expected.
Thanks bro. Good first reply.
How would I wire a brushless motor in a simple circuit ( battery - switch - motor ) using the third wire to get full speed all the time.
The goal is to not increase rpm too much but add a lot more torque. Any recommendations ?
Here are some more specs of the current motor:
1.Brand: MABUCHI MOTOR
2.Model: RS-360SH-3560
3.Motor diameter: 27.4mm
4.Motor height: 32.3mm
5.Output shaft diameter: 2.28mm
6.Output shaft length: 9.35mm
7.Weight: 55g
8.Test data
Voltage:3V Speed:6300RPM No-load current:0.37A
Voltage:6V Speed:12600RPM No-load current:0.44A
Voltage:9V Speed:19000RPM No-load current:0.52A
7.Weight: 55g
8.Test data
Suspended
the "380" size motor is common in 1/14, 1/16, and 1/8 scale RC cars. Hobby shops should have some on the shelf. There are plenty of brushless motors in this size, but you need an ESC that is compatable with brushless (most brushed esc's have a red and black wire to the motor, brushless RC motors have 3 motor wires. You need all 3 brushless wires connected properly for the motor to work as expected.
You don't wire the motor that way. The Battery has the 2 power lead that will go to the ESC battery wires, the ESC will have 3 wires that go to the motor usually labeled a b c and the motor has an a, b, and c tab. You have to wire A-a B-b and C-c or the motor wont run.
The ESC Controls the motor all the time from standing still to Wide Open Throttle.
Then you can program the ESC to control the motor various ways as you use the Tx Throttle trigger.
One major thing what is esc or supply voltage. we know its a 380 size brushed motor.. op asks for better performance . that again with out knowing old motors specs as in winds we cant give him a drop in fix..
Voltage?
turns?
Voltage?
turns?
lets not confuse the repairer any more. whats this motor going in? brushless would be nice but we have no idea what its going in.
To the OP Tim F means 1/18th size, not 1/8th. He missed the 1.
Any brands or models you guys prefer when it comes to motor shopping.
Don't need high rpms, just want torque for days baby !
Suspended
The hiccup here is Brushless motors are 3 phase, while Brushed motors are 2phase.
You could run a mechanical on off switch. Its not really rocket science. but you do need to convert a 2 phate circuit the battery pos and negative, and covert that to 3 phase, equally distributed to all 3 phases.
Thus the ESC, which does exactly that, and more obviously.
If you just want to hotwire a motor battery together install a momentary contact switch on the negative lead, and use a servo/receiver adn small pattery pack to power the servo, and use it to engage the momentary contact switch. But you're going to get full tilt on the motor, whatever juice the battery has.
If someone is thinking that may be the key in No Prep, you got another thing coming. lol
I'm limited by a small form factor . Unless they make really small and simple ESC's again I'll stick with brushed motors.
What are ways to make a motor perform better ? My goal is to get more torque.
I'm limited by a only using a single cell battery and a small form factor.
If the goal is more torque with a slower speed being acceptable one option is to use a gear motor or a gear reduction unit added to the motor. Not unusual in the robotic or airplane fields. Tradeoff is the space required. Some examples here: Brushed DC Gear Motors
Excellent bro.Do you know of any others similar to this ?
Excellent. Thank you bro.
Btw recently learned that they do make brushless motors that run off 2 wires. The catch is that they have an ESC built inside... A computer fan for example
Contact Holmes Hobbies. They sell and wind an assortment of motors, both stock and custom for the rock crawler market. They can direct you with some degree of confidence around brushed motors.
For best results, avoid calling anyone "bro" in your email...
