Team Associated T6.2
#109
Any pro driver setups out there? Just picked mine up. Always like a nice start.
#110
I'm building my t6.2. As I have a pretty tricked out t6.1, I have been comparing them. Am I mad, or is the chassis longer? My chassis protector is short, and my old body does not fit. I just looked at the t6.2 website, and don't see anything about a different chassis?
#111
I put a chassis protector on mine, it fit fine. My son's T6.1 body will fit my T6.2. You sure you didn't assemble something wrong?
#113
Just like most associated kits it built just fine. I wouldn't mind some manual suggested carpet starting setup or a spec motor sized spur in the box. But there is nothing like popping open that good Asian air in those fresh kit bags
#114
#115
I have a T6.1 which I upgraded to a T6.2. I purchased the V2 body post set and found that the V2 rear spacer is about 4-5mm longer than the spacer from the T6.1 kit.
I also have the Associated chassis protector which is a few mm shorter than the chassis.
#116
Manual state that it is T6.1 chassis plate. Maybe your chassis protector sheet is for the b6.2?
#117
Might not be an illusion.
#118
t6.2 editable setup sheet is at: https://site.petitrc.com/setup/associated/setupt6.1/
I have not fund any t6.2 setups, but the default.
#119
Thinking of putting one of these on my list of cars to get. Having a hard time deciding which brand, AE or Xray. What other options would be good to get to run one of these on a small black carpet track with slicks? I assume a gear diff, but what about springs and other upgrades?
#120
I bought aluminum steering rack, the arms it mounts too and aluminum front pivot. That stuff and maybe swap the pivot for brass for carpet and plus springs. I don't run on carpet, you'd have to look up some t6.1 carpet setups and start from there.
It includes a laydown transmission and aluminum electronics plate which were common upgrades for high grip/carpet. Oh and a front sway bar too.
I expect it to be pretty dialed out of the box, my t6.1 was awesome when I sold it. Plus its all half the price of X ray without their insane list of options for each part. The gullwing arms should be the thing the last truck was missing.
