Help me decide which 1/8 buggy 4x4. Kyosho, Arrma or other...?
#35
After checking with my other local hobby shop regarding two 3s lipo battery selection (which is still 60 miles away just the other direction), the hobby shop guy recommends not running two Wolfpack 3s 4500mah 35c lipo batteries in the Typhon. He recommends two 50c minimum due to much less chance of putting too much strain on the batteries. Mentioned he's seen running less than 50c batteries in the Typhon (or like vehicles) shorten battery life significantly too many times to recommend it. So if I come in and pick up two new 3s 5000mah 50c batteries he has in stock (said he has a couple different ones) he will match the price of the smaller Wolfpack batteries, which are $61 each. Said he just doesn't want me to waste my money. What a nice lad. Sounds like a good idea to me.
#38
From what I’ve read the Wolfpack is continuous 35c with a 65c burst. That’s 157amp continuous or 290amp burst. Getting those sorts of draws on 6s you’ll likely break the space time continuum Ie run the battery down in under 1-2 minutes. A runtime of 10mins is 6c. 5min 12c 2.5min 24c... C ratings are like power ratings on stereo amplifiers... mostly bullshit. Reputable lipos such as reedy are probably realistic C compared to other brands that put unbelievable numbers that can not be easily tested. Your hobby shop is perhaps being a little conservative. Castle Creations as an example spec 5amp batteries with 25c.
the benefit of bigger amps for your situation is runtime. If you’re driving 60mile I’d get a number of packs. Running one set then waiting to recharge would be painful. Also get some proline badlands if you’re running in loam. The lugs on the standard tires looks a little low.
Battery Run Time Calculator
#39
#40
In short, at 6S you won’t have an issue. 3S you may have an issue. Power = volts x amps. Halve the volts and you’ll double the amps needed to get the same power. 35C is a safety margin for manufacturers who state C ratings but may not be clear whether that’s burst or constant and for you to make an easier decision rather than refer to forums. If your motor pulls 200+ amps @ 6S continuously the motor/esc will likely melt along with the lipo. To do that you would need to bolt on truggy type belted tires, sauce them, put in the biggest pinion then go do multiple speed/braking runs on sticky asphalt. Or run flat out through long grass while towing your dog. If don’t do anything extreme nuts, you’ll be fine. Enjoy. And for the record both bodies look pretty good.
#42
There are only 2 brands of batteries that I personally stay away from:
- MaxAmps
- GensAce - I got burned on a lost leader sales tactic, won't buy from them anymore
#43
Speaking of lipo batteries, are there certain brands to stay away from or mostly known to be "cheap"/crappy?
Also, over at the Arrma Forum, lots of people love the CHNL packs, especially the G+ line. Great price, and the they seem to be good quality.
#44
#45
For me I avoid anything Team Orion / Performa (expensive crappy batteries) - they have no support should anything fail.. A lot of brands are simply relabelling from the same manufacturer in China or Korea. I’ve now gone to cheaper packs. So far I like NXE Power (not sure if that’s in US). Guys at my track use turnigy and eco power and haven’t had issues.
