Team Associated B74.1
#736
Ok thanks. I actually am running a shorty servo but also the HW xr10pro, I believe its the older version and supposedly 95g. I'm unsure of the motor right now, other than its a 13.5, motiv maybe. I am running a 6000 mah battery I think, but I have others, so maybe a weight savings to be had there. Might be a 5500...cant recall right now. Oh what I wanted to say is I am easily 100 - 150g maybe more over what the legal limit at the track is. I don't even weigh it because I know its that heavy. lol
#737
It'll likely always be a heavier car than the TLR or Xray due to the adjustable diff height system - it's one of the reasons I sold my B74.1 for a 22x-4 elite. On top of the other items mentioned (LCG battery and stock spec esc), you'll be able to save a decent chunk of weight by by using the carbon side pods (link). Other than that it's various carbon and titanium goodies but you're only talking a few grams here and there.
If running on astro, any benefit to running the plastic gears in the diffs? Right now its set up with the stock stuff. I could see a weight savings there too I bet.
#738
Thank you! I'm not that worried about the weight because sometimes that effect handling too much and negatively. My yokomo 2wd cars always liked to be heavy, and any attempts to cut weight on them negatively effected performance. With the 1588 gram minimum, I'm more like 1700+ grams. So even 30-60 grams of savings would at least get me closer.
#739
Hi all,
Is there anything that was left out in the installation manual ?
Heard that
1) shock absorber, AE did not tell users to add in limers (or whatever)
2) rear arm spacer too thick, need to file it thinner
3) pills not labelled
4) servo horns indicated wrongly in manual
Has this issue been solved ?
Heard that
+ YouTube Video | |
#740
Hi all,
Heard that
Heard that
+ YouTube Video | |
2) I personally did not have to file anything down on this build. I have the dirt version
3) pill are labeled by dot location, and whether it is .5 or 1. Setup dependent.
4) Stock is a 20 mm horn, some people run 18mm. I would suggest a aluminum horn.
I hope that helps.
#741
1) Depends on the setup if you need limiters or not.
I hope that helps.
I hope that helps.
Had to adjust the length of the link between the horn and bellcranks, though.
#742
In what way? I run the 20mm, and all things being equal, would you not have to adjust for anything? I cannot picture what would need adjusting, maybe the spacer to clear on the shorter throw.
#743
Same is true on all of the copy cat 4WD's. If you can run a shorter horn it takes the edge off. Or like in the case of the 22X-4, they run a longer Pivot Arm on the servo side of the Bell Crank, which has the same effect.
And depending on the angle the link between the bell crank and horn sits, it will have to have the length adjusted slightly so that on center with the servo is still on center with the bell crank.
With a shorter horn, the link will drop slightly, which would move the ball stud away. As the link dropping down, would also swing it away from the center line of the servo horn.
If you need to visualize. Take a ball point pen, and set it on a piece of paper. Mark where each end of the Pen is on the paper. Now on one end of the pen, draw another dot one inch directly below the first dot. Keeping the other side of the pen on the dot, swing the other end toward the dot you just drew one inch lower. Notice there is now a gap between the end of the pen, and the dot. This is because the pen is not long enough to reach that length, because as it swings down, it also swings away on the radius.
Now shrink that down so the fixed end of the pen is the bell crank arm. The pen is the turn buckle link. And the two dots represent the 20mm and 18mm servo horn. So shrinking the length of the servo horn means you lengthen the connection, and vice versa.
Make sense?
#745
Shorter horn makes for a slower steering ratio, which calms down the steering.
Make sense?
Make sense?
#746
Maybe I started off one click left/right of you on the servo itself. Or maybe we have servos with different numbers of teeth. Or maybe different servos are at different angles. Or maybe you or I have more/less spacers between the horn and the ballstud.
Either way, it's perfect now on both our cars and made a positive difference in handling
#748
Best Titanium Turnbuckles
What are the lightest (read best) titanium turnbuckles for thr 74.1?
#749
I don't think I've ever seen weights published. I've used Lundsford on 5 builds, never bent one - they've been making turnbuckles for a few decades, and doing it right. I usually get mine through WallieBuilds in sweet colors, with rod ends, pre-built for the same money as just the parts to DIY.
