For what your planing on doing with this kit, I would check out this option!, it will fit a lot better in the chassis than a castle unit. https://www.hobbywingdirect.com/coll...14796877398131
Is this a necessary upgrade for the original eb410?:
If your going to need to run 2 fans just make sure the fans can run on your batterys voltage.. a Y harness for the 2 fans will do no harm . how much will then fans need and use?
Should I buy this for my original eb410?:
If your running an original eb410 aluminum shock caps are a must.
That esc and motor combo is more along the lines of a monster truck setup. Go with the 5700k for the eb410. It will be super fast. I had the 5700k in an hpi blitz and on 3s the front would not stay down at top speed.
Originally Posted by Clodbusterfan
(Post 15654445)
dtr: Why would a higher kv motor be better? Won't a higher kv run hotter than a lower kv motor?
| All times are GMT -7. It is currently 03:39 AM. |
