PR Racing - SB401R-T (1/10 4WD ST/Truggy)
#17
Vendettahobbies.com and thercproshop.com/shop
vendetta hobbies is actually running a special for the next 7 days and pre-orders during that time will be 10% off using the code "#PR Racing FTW"
Should be in the next month maybe little more, Nemo USA will also be available
#18
#19
OP
Build is very nice and tight, no slop anywhere. You will get 2 full sets of hexes, so you can choose to run the PR wheels or can run AE style offset wheels. 2 full sets of springs, PRs newest serated wheel nuts. Has machined shock pistons as well as few different sizes of the molded pistons...I cant upload the videos from last night at the carpet track as it says they are the wrong style of files or something...but I was super impressed with how well it did with a guess for a setup. It would take the sweeper flat out and would turn on a dime. But my shock tune was off some as it was little bouncy on flat landings. But overall I'm stoked as it was still felt really fast and can only get better. And was using a 8.5t with little timing actually on the can and under geared some....I did have a few option parts on it, 1.6mm front sway bar, aluminum bellcranks, one piece shock standoffs ,and the rear wing center stabalizer and wing buttons....stock front sway bar is 1.4mm for anyone wondering...I'm going back Friday as it's the last day for practice as the track wont be open this weekend. But I'll make a few changes and hopefully have a decent starting setup to share.
#21
Front 1.6mm sway bar is from the 401R as they are the same lengths for easy compatibility.... and i had extra sets of bellcranks so I put them on....almost all option parts for the 401R are compatible with the RT so theres plenty available if someone wants.
#24
Trader Rating: 53 (100%+)
Man I'm really liking this truck. I'm trying to get my butt back to the track after several years absence. If I can get back to racing regularly this truck is definitely on my radar!
#27
Yeah that's a decent amount of weight shedding right there lol.
#28
What is the weight difference between those two sets of tires? Are they using the exact same electronic setup? Make everything even if you intend to make a fair comparison.
#29
Also note that my ET410 has over $300 in upgrades into it, many which reduce weight from box stock weight!
#30
My RT which is the unpainted one has full size electronics with ae wheels, the painted body one is the owner of PR also with full size electronics and PR st wheels. Pr ST wheels are some of the lightest available...so them and the tires are the biggest difference between the 2 RT showing weight..
Owners electronic setup
My electronic setup at the moment..i wasnt to worried about making it super clean wiring until my new motor and esc show up
