Like Tree1Likes
  • 1 Post By big ted
Tire Sauce
Old 01-24-2019 | 01:17 PM
Larcor69's Avatar
Default Tire Sauce
What the hottest tire sauce for indoor clay, home made preferred, ain't seen anything post on here since 2017
Larcor69 is offline
Old 01-24-2019 | 02:11 PM
Johnoly99's Avatar
Default Saucy
yhe best for clay/hard dirt is stickykicks yellow. Home made? Dunno sorry never made my own (yet)
Johnoly99 is offline
Old 01-24-2019 | 02:36 PM
I also use sticky kicks but use either the orange or purple
Kelseyrc is offline
Old 01-25-2019 | 05:37 AM
Your favorite Tire Sauce recipe
billdelong is offline
Old 01-25-2019 | 12:16 PM
For homemade sauce liquid wrench yellow or pb blaster both work pretty good but if not careful can balloon the tires . I use Trackstar Gold and Black and they work great . use gold to brake in tires or to get them softer and black to maintain the tire once you get it where you want .
Racer56556 is offline
Old 01-25-2019 | 01:39 PM
socalcloin's Avatar
I like liquid wrench blue but it is the lubricating kinds so it drys slow, I normally wipe it off after 10 mins. I switch between it and Sticky Kicks orange that I actually watered down so I would get some more use out of the bottle, but you must shake it or you might get mostly water and no extra grip. Really the water is not recommended.
I actually read people were mixing Liquid Wrench blue with either Sticky Kicks or a faster drying spray like brake cleaner so that it will dry up, but who really knows except them?
Its all tire dope to me.. but honestly the reason I don't just stick with the cheap Liquid Wrench Blue is because the fumes it gives off even though I sprayed it into an applicator bottle.. I don't like to use it multiple times in the same day.
I don' know what sticky kicks is but I can use it multiple times on two cars in the same day and the smell/fumes do not bother me.. in no way does that mean it is any safer though.
If you want something super cheap and easy go WD-40, that is an old time favorite. People mix it with PB Blaster or brake cleaner or I think hairspray?
If you want my personal recommendation would be to order the bottle of sticky kicks Yellow, it is just one touch down from orange. Use a good applicator bottle so you do not waste any and it will last awhile.
Clean/dry tires then apply Sticky Kicks yellow 10 mins before your run. Should be good to go.
socalcloin is offline
Old 01-25-2019 | 02:51 PM
I'm actually kind of surprised this stuff gets sold without an MSDS sheet describing what's in the bottle to be aware of.
socalcloin likes this.
big ted is offline
Old 01-25-2019 | 02:53 PM
TeamSkunkwerks's Avatar
R/C Tech Elite Member
Talking Homemade Tire Sauce
STP OIL TREATMENT
GRAPE SODA
STICKY KICKS ORANGE
APPLY TO FOAM OR RUBBER TIRES & LET SIT IN A ZIP-LOCK BAG OVERNIGHT.
REAPPLY 15 MINUTES BEFORE RACE & LET SOAK IN TIRE..
WIPE OFF EXCESS JUST BEFORE RACE START.
RECOMMENDED FOR EITHER DIRT OR ASPHALT ONLY
TeamSkunkwerks is offline
