sc10
sc10
I have just got back into the sport. It has been a couple years. I recently purchased a stock sc10. The only upgrade it has is the hex setup. I did have to replace the servo and notice the chassis was cracked where everything is connected together. What all would you recommend to upgrade on my truck? BTW I am running a reedy 3300kv. Thanks in advance!!
if your racing , replace the parts with stock pieces. If bashing you can go with rpm pieces. The limit is endless. Are you racing or bashing? dont forget to check out petit rc for the endless setups
tie rods , and removing the dog bones and replacing with cvd's would be my first options. The dog bones will fly out and get lost if a tie rod lets go.
I will be racing, outdoor and indoor clay.
If you’re racing immediately, I would start with whatever tires the others like and put them on +3mm wheels, then get a hi-flow/flotek body. If you bought a new RTR (10.3), lube the diff and adjust the slipper before the high traction of the clay tears up your idler gear (like happened to me). Personally, I wouldn’t go beyond that for now (except for upgrading parts as they break) as you might want to change to a mid motor vehicle sooner than you might think.
Thanks!!!
