Kyosho Ultima RB7 Thread
#76
Standup
Done that
#77
Hi everybody,
I have a questions for all. I'll buy an RB7 (Hesitate with a Schumacher, so i hope it will be good for me ).
Which parts i need with the car ? Swaybarre ? Springs ? And ?
Some other option parts ?
Do you have a good basic setup for astro medium traction ? And EOS carpet ?
I'm coming from TC car, so it's new for me
So, if you have some advices for the car...
Thanks a lot for your answer.
Best Regards,
Best Regards,
#78
I run loose out door 8th scale track, just been using the 3 gear stand up, found the car better on bigger pins than the b6.1d, I.e I now run blockades where I would have run holeshots, from kit I went front shocks in on the arms, Long front shock ends, long rear shock ends, more rear toe in on the rear (D in - D out on alloy hangers)
I found under lipo weights counter productive.
#79
Hi everybody,
Best Regards,
Best Regards,
For astro and carpet, I would recommend:
-Red, yellow front springs
-Red rear springs
-Alloy rear hubs UMW704-0 are a good upgrade as stock are a bit weak
-Front and rear CF shock towers UMW 739 and UMW740, better suited to the car (different geometry)
Swaybars are available for rear and soon for front, but you don't see those used on current setups.
As for setups, the Marsden one is really good on astro. The Akimoto Hertz seems better on a twisty, small astro track. As for carpet, I don't have yet tested the RB7 on carpet but I would go with the Akimoto Yatabe one.
#80
Thanks for your answer.
I'll start with the first setup and i hope it could be good for me.
Do you know how can we mount the front wing ?
Best regards,
Manu
Best regards,
Manu
#81
Tech Legend
Trader Rating: 51 (100%+)
Anyone running a front wing on the RB7? If you are which one did you go with? I see JC makes one for the RB6.6 so wondering if that setup would fit the new RB7.
#82
I currently run the JC front wing mount from the 6.6 and the UMW744 Kyosho Front Wing and they work great....
#84
Ran the Rb7 on indoor clay high bite track , car was much better than the 6.6. I ran Zach Rogers setup but went up 1 spring on the front to take away steering (Associated Orange) didnt have next harder in the Kyosho range. The car felt so much more balanced, and really liked to be driven, held more corner speed......you will like it a lot
#87
Where do you even find parts?
#90
Ran the RB7 this weekend for the first time. Buggy ran smooth and jumps great had great traction all day long.
