Kyosho Ultima RB7 Thread
#436
Changing gears, I was able to get a nice selection of upgrades from a terrific forum member here. Actually I have met a couple of really great guys here with Kyosho parts and accessories. For now I was focused on upgrades rather than spare parts but that will likely change in the future. The aluminum steering arms that were part of the package are from the rb6 not the ones specifically for the rb7 which seem to be longer. At least that's what I assume the "L" engraved on them means. Does anyone know how the rb6 arms will affect the handling on the rb7 buggy? Likely the two guys I mentioned will see this here but if not I will PM them
#437
Hey Milkdudd.
Amain Hobbys has that battery post mount your looking for. The have it in stock for online purchases.COVID-19: We ask for your understanding as you may experience delivery delays.
KYOUMW754
Kyosho
Related Products
In Stock Online
Usually ships in 24 hours
$1.99 flat rate shipping! Learn More Price: $14.49
Add to Cart
Save In List
Write the first review
AMain Hobbies Chico (Check Others)
Chico, CA
(530) 894-0796
Out Of Stock In Store Learn More
This item earns up to 14 VIP Reward Points
Kyosho RB7 Aluminum Battery Post Set
KYOUMW754
Kyosho
Related Products
In Stock Online
Add to Cart
Save In List
Chico, CA
(530) 894-0796
#438
I think it's a good idea but like I said don't wait too long. If you buy $30 or so additional to get to $250 you can use a $25 coupon at Absolute Hobbyz. The way I look at it, if I was going to buy that other stuff anyway it's like getting the car for $195. Plus they are really great guys that are a pleasure to do business with.
This site will pretty much let you know how flat arms will affect the RB7.
Razor RC blog: Team Associated B6 / B6D flat arms vs. gullwing arms
#439
Exotek is by far easier to use. You only have to turn the tabs. However, you will have to drill holes in the plastic sides to mount it, if your running the battery sideways. I put foam strips on the outside of the channels to allow a tighter fit. Make sure you put the arms on right-side up. The Exotek is also cleaner because you don't use foam for spacing.
#440
#441
Installed my aluminum steering components on the rb7 tonight. Dimensionally they are identical to the original plastic parts. So I haven't had any changes in geometry. The rb7 specific bellcranks are 2 mm longer than the kit versions so those would be the ones to change geometry. I'm glad that by pure dumb luck I ended up with the standard kit geometry aluminum components
#442
#444
Has anyone experienced breakage of the factory steering components on the RB7? I heard of the servo horn breaking, but nothing else. I'm curious if I should swap mine out for aluminum.
#448
Thought thought I saw it happen to a lot of guys when the RB6 was first released. Had them wanting the aluminum one. Might have been a first batch thing because I don't think I ever heard of the 6.6 or the 7 having that issue. I just kind of go aluminum from the get-go. I just have a thing for anodized aluminum in cool colors. Especially the chocolate brown Kyosho color
#449
Never seen one break personally, but I have always used an aluminum steering rack, be it Kyosho or Exotek, but have used both aluminum and the stock wiper arms with no problems.
I would go with at least the rack if you can. It will definitely be a more direct feel and you won't have to worry about pulling a ball stud out of its threads.
