Team Associated SC6.1
#676
Wheel nut coming off
I keep loosing LR wheel nut. I've tried different nuts and still having problems. I even had a problem with double nuts coming off. I'm using Jconcepts Hazard wheels.. What going on??
#678
Does anyone have a set up on the sc6.1 for sc mod dirt oval on a high bite track? 13.5 motor blinky esc for this class.
#680
I always run this body for my SC6.1 and et410/SCT:
Pro-Line Flo-Tek Pre-Cut Fusion Short Course Body
#683
#684
anyone know the part # for the plastic end links that attach the front anti roll bar to the arms, bought the incomplete roll bar hardware kit which doesnt come with all the hardware and cannot find the end links in the manual or anywhere? thanks
#686
SC6.1 ROLLING OVER ON MEDIUM BITE CLAY
Has anyone had trouble with the truck acting top heavy and rolling over upside down even with tires that for sure are not getting to much traction. I have tried a few bodies lowered to where they even barely rub the tires at times, my sc5m I can attack the corners.
3 and 4 gear stand up tranny.
Medium bite clay
Any ideas
Medium bite clay
Any ideas
#687
Medium bite clay
Any ideas
Medium bite clay
Any ideas
#688
I have a really well equipped T6.1 and I'm considering a conversion to an SC6.1. First question is would this be a good idea or does it make a lot more sense just buy the SC6.1 outright? From what I've seen on YouTube videos it seems a few have gone in the other direction. If I decide conversion is the way to go I will post in the wanted to buy section to get the parts I need. Maybe one of you reading this have what I would need to make this conversion and we could make a deal. Thanks
#689
SC6.1 set up for loose bumpy surface
Hello everyone first time thread user hear so forgive me if I do something wrong. Just picked up an SC6.1 kit with everything to do the 3 gear stand up trans, last car was an original sc10 so I am looking for a bit of advise on setup for a loose bumpy track. I have my wheel/tire setup situated but need guidance more for the rear pills (toe, pivot width, roll center and anti squat) as I have never been able to tune this much out of the box and would like to take advantage of this for my specific track conditions. Not really sure about the front kick optional caster and knuckle height either, not too manny people desire a tune for loose bumpy surface anymore with today’s clay/carpet/turf tracks so I am finding the info hard to come across (or I am not looking in the right place) haha
#690
For those of you running a gear diff in your Associated 2wd vehicles or SC6.1 are you using the 91782 o-ring on the planetary gears? The instructions say it is a tuning option but not used on the kit build.
