Team Associated SC6.1
#511
as Celt stated.
and
back off the throttle about 6 inches before the upper EDGE of the jump.. in mid air, if still nose high.. move the throttle forward to lightly activate the brakes..
works for me. but I have a SC5M...
and
#512
I wouldn't recommend running any drag brake if your running 17.5 class as this creates unwanted heat build up in the motor. Like the other guys said, check to make sure your not holding the throttle on after the truck leaves the face of the jump. If your certain that your not and the truck is still nose high, then make sure you have cut outs on the body to help with any possible parachuting that may be happening. If there is still an issue then check to make sure that nothing is binding in the front and/or rear of the truck with the arms or suspension components.
#513
Need some help, I have been running my SC6.1 now for a couple of months. I am running stock spring, set up at 28 ride height. I am running 35wt in the front and 30 in the rear. Rear shocks are mounted toward the front. I am running slicks at my local clay track. I am running the battery forward and am using the brass front weight. My question/problem is with jumping, this thing is goes way too nose in the air and I cant get it settled down where I can get it nose flat or even down. This was the case outdoors as well. What suggestions can I start with to get this resolved?
I also found this truck doesn’t jump right but ended up running a lot of weight and heavier springs all round with 35/30 oil and it’s been much better.
#514
Matter of fact, I find the SC6.1 to be pretty darn neutral - a little throttle or brake input and the chassis does exactly as I need.
#515
I can't speak to what others are doing with setup, but I've no issues whatsoever in regards to this truck jumping properly. Nor do I do any setup changes much beyond what's pretty much box stock. I've run one stiffer spring up front on one occasion and a lighter spring in the rear...neither of which caused the truck to do anything abnormal in terms of jumping.
#516
#517
Thank you to all. When running a SC5m, I really didn't have this jumping issue, it jumped flatter. I have some ideas to try out. Of course one at a time.
Some mentioned heavier shock oil in the front, what ill effects would this have? I have 35 in it now, I would be interested in trying 37.5. Currently I have the steering dialed where I like it. I don't want to lose that.
#518
How much anti squat are you runing?
#519
#521
Going to 37.5 will take away some of the snappiness this truck has when turning. If all you run is this truck and your good with 35 weight oil up front then stay with it. I run buggy and ST so driving this thing is hard to adjust to after running the other two cars on a club race night. Going heavier up front with the oil allowed me to drive this truck a bit more like my buggy.
i actually run a eb410 and a b6 along with the truck on club races. I’m thinking I will try the heavier weight and see how she does. I’m not opposed to trying different things.
#522
#523
#524
Hate to see someone chase around in circles, moving away from known good setups. I suspect it's something to do with throttle response, drag brake or maybe even a bad jump face. I see nothing in what I know of your setup that would cause what your are seeing. In other words, if you have to do something drastic that others don't have to do, something else is suspect.
