Looking for motor to pair with castle creations sidewinder 3 >
Old 12-06-2017 | 02:52 PM
Default Looking for motor to pair with castle creations sidewinder 3
Hi guys,
Building another slash for my boy. I have castle creations sidewinder 3 and am looking for a motor. Can I use reedy 3300kv motor?
nyigor is offline
Old 12-06-2017 | 02:56 PM
EbbTide's Avatar
Originally Posted by nyigor
Hi guys,
That motor should be just fine for the slash and that ESC Just be prepared for a little cogging when at low RPM due to it being a sensorless setup.
EbbTide is offline
Old 12-06-2017 | 03:00 PM
For whatever reason, I can't find cc 1410 3800kv motor. I found only couple used ones on ebay. What would be the good motor choice to pair with sidewinder 3. I am googling and can't seem to find any info. Only pairing with traxxas stock motor.
nyigor is offline
Old 12-06-2017 | 03:06 PM
Hi guys,
Which Reedy is it? The older 2 pole, or the newer 4 pole? Reason for asking is you need to watch temps on the old 2 pole motor. They like to run hot. I'm running an older Reedy 3300kv 2 pole with a VXL 3s esc in my Stampede. I have it geared pretty conservatively at 18/90 and it will climb up over 150F on a 2s in around 10-15 minutes. It runs 31mph. I really like the motor for the application, but gearing up or running on 3s would probably fry it.
Thumper01 is offline
Old 12-06-2017 | 03:08 PM
Reedy 3300kv 4 pole sensorless. Motor will only see 2s since my boys is turning 5.
nyigor is offline
Old 12-06-2017 | 03:10 PM
EbbTide's Avatar
Here this is the updated motor. It is sensored capable but should run sensorless just fine when paired with that sidewinder
Castle 1410 1Y Sensored Motor - 3800Kv
EbbTide is offline
Old 12-06-2017 | 03:12 PM
The Castle 3800 is a fantastic motor. Big time power. Also a good fit for your Slash would be the Velineon 3500, Castle 4600, previously mentioned Reedy 3300 - preferably the new 4 pole, RC Gear Shop 3900, or any other motor between 3000kv-5000kv.
Old 12-06-2017 | 03:13 PM
Yep. That'll work fine!
Old 12-06-2017 | 03:15 PM
I was reading about sensorless and sensored motors a while back and I kinda decided on sensorless. Those exposed welds, are they safe like that? I am sure we will use it in wet conditions.
nyigor is offline
Old 12-06-2017 | 03:16 PM
Yes, indeed. I have it as a combo in my other slash. I love it but since I already have sidewinder, I am struggling to find a good match.
nyigor is offline
Old 12-06-2017 | 03:19 PM
EbbTide's Avatar
Those are just the solder tabs for the motor that they added so that people can rewire their motor however they'd like. Should be perfectly safe in wet weather. When actually running a sensor wire from the ESC to the motor that is when wet weather should be avoided. But the Castle motor can be run in sensored and sensorless mode.
EbbTide is offline
Old 12-06-2017 | 03:23 PM
And with reedy motor, I am assuming I will need to redo the connectors as they are 3.5mm.
RC gear shop seems to come with 4 mm.
nyigor is offline
Old 12-06-2017 | 05:38 PM
Can someone please confirm if 4 mm bullet connectors are male or female on RC gear shop motor?
nyigor is offline
Old 12-07-2017 | 07:36 AM
Male
