Off-road basher tires for 1:10 buggy?
I'm looking at off-road tires for 1:10 buggies, but they all seem to be for clay or carpet, which is ridiculous, because to me off-road means dirt and grass. Hardpacked dirt is probably not *too* different from clay in terms of the tread pattern required, but grass is very different -- it requires a tread similar to motocross tires. I can't seem to find that in a 1:10 buggy size, though. Can anyone recommend some decent basher tires for a 1:10 buggy?
I suppose I should mention it's a 4WD buggy and it has narrow front tires, so it would be nice if the front and rear tires matched, or at least had different tread patterns designed to work together.
Proline bowties or jconcepts goosebumps. There may be something out there that is more aggressive. But those are the first ones that come to mind.
T760 1/10 Tiger Rear Buggy
You probably want to look at turf/carpet tires as I believe they usualy run more pin style tires and are usually somewhat beefy until they trim the treads for their track.
I've used these with good luck on grass dirt & gravel. The wheels suck, but the tires are nice and grippy.
https://www.amazon.com/gp/aw/d/B00ID51M9W/ref=yo_ii_img?ie=UTF8&psc=1#
I have a set on my daughter's RB5 now, fronts are 4wd sized so not too narrow.
schumacher makes good "true off road" tires. I like the proline blockade's too also the dirt hawg's unfortunately proline discontinued the 4wd fronts
Proline Dirt Hawgs work well for bashing.
Those Schumacher Blocks also look promising.
Pin-tread carpet tires would probably work, but I'm concerned about whether the rubber compound could actually withstand mixed-terrain driving.
https://www.amazon.com/gp/aw/d/B00ID...ie=UTF8&psc=1#
Maybe something like these.
More than likely just a Chinese brand that stole the molds from a known tire manufacturer. They look like Arrma Raider buggy tires but could also be older Duratrax or Schumacher offroad tires from years back.
