Go Back  R/C Tech Forums > General Forums > Crawler Room
what competition crawlers the best? >
Rate Thread
Old 12-24-2014 | 10:55 PM
Default what competition crawlers the best?
im looking at buying a competition crawler. what are the top ones out? i was looking at an axial xr10 is it worth it? or are there better ones then that?
rcbasher97 is offline
Old 12-25-2014 | 05:34 AM
If you are lookin into MOA rigs I would say XR10 is probably the most supported rig out there. The aftermarket support is never ending. There are axle manufactures like Enroute Berg but they haven't made anything new in years. If you are looking at complete kits my top 2 would be Axial and Losi. Everyone else is sub second teir.
Phins Fan is offline
Old 12-25-2014 | 05:46 AM
if you bought anything new moa what would it be?
Old 12-25-2014 | 06:45 AM
That's the thing. There really isn't anything "new" on the market. Unless you go with an Exceed which I wouldn't recommend cause quality kinda sucks and replacement parts are hard to come by. I currently have 3 comp crawlers. 2- XR10's and 1 shafty. The XR's are by far more capable than anything I've come across as of late.
Old 12-25-2014 | 06:51 AM
RC4WD just released their new "Bully 2" axles not long ago...
http://store.rc4wd.com/Bully-2-Compe...le_p_3324.html
gdb85 is offline
Old 12-25-2014 | 09:00 AM
sounds good, might just start out with a xr10! thanks
Old 12-25-2014 | 09:36 AM
*Super*'s Avatar
Be prepared to spend a lot of money on an XR10 to make it last longer than 2 min. They discontinued it a while back. They are very fragile in the stock form. I would go with Bully axles and an aftermarket chassis. RC Crawler has sections set up for the individual crawler types and brands out there and you can make a better decision that way.
*Super* is offline
Old 12-25-2014 | 10:55 AM
I know the scx10 ismore of a scaler ,but iv had no problem with durability a few miner upgrades for my driver preference, and axial website is a big help my win is axial ! Also u can pretty much find anypart for the ax 10 in anycolor imagined on ebay.. So it tends to be pretty awsome..
micro510 is offline
Old 12-25-2014 | 03:59 PM
ahh i see. i like the wraith too. im interested in crawling not rock racing. so it would come down to the scx10 and wraith from axial wouldnt it? idk what i want now hahha.
Old 12-25-2014 | 05:49 PM
i really just want something that's able to crawl without flipping over a whole bunch. what do you guys think is the best rtr crawler?
Old 12-25-2014 | 07:23 PM
BLKXJ96's Avatar
If you don't plan to use the truck at a serious comp and are just using it to run around on trails get an SCX10 or a Deadbolt. If you want the best comp crawler those are built from parts, the XR10 is about the best kit option, but I would recommend RC4wd gears. Do some research....... some of the MOA rigs cost can approach $2000 dollars pretty fast.
BLKXJ96 is offline
Old 12-25-2014 | 10:22 PM
is the wraith spawn any good compared to the deadbolt and scx10? im ordering tomorrow morning!
Old 12-25-2014 | 11:08 PM
I got the scx10 as im new to crawling also the wraith and scx10 will be around for awhile so dont feel to pressured. I got the scx10 and im going to go 2.2 tires on it wraith size ,I like the size of the wraith ut they both have the same setup just diffrent model if u will. Scx10 is the official truck of the g6 ;p just saying!! Id like to hear what u get il e getting my upgrades soon il post pix
micro510 is offline
Old 12-26-2014 | 01:24 AM
Default wraith
I just got a new wraith kit and built it. So far I am happy with the truck, LEDs from advance auto. Strc alum, and working on 4 wheel steering. And bead lock axial rims. I don't not want the dig and glad I went with 4w steering. I got a new front axle and built it like the rear. I am using strc alum steering linkage cause u can flip it over and use it on either end.
S.TRIPP77 is offline
Old 12-26-2014 | 02:17 AM
Wow so this took a turn in a different direction. If you are gonna scale instead of comp and your worried about always flipping that I would suggest a Deadbolt or Wraith. They both utilize the AR60 axles set which are wider and have a longer wheelbase around 14" compared to 12ish" for a scx than standard axial axles and offer up more stability.plus they both can go considerably faster than a SCX.
