Trail honcho with problem
I jus put a new high torque steer servo in my honcho and it seem to steer 1 way well and the other poorly if at all .... Along with my new servo also upgraded to a 55t motor which cuts in and out .....I'm lost lads got no idea esc is brand new not sure the brand but it was bout $115 transmitter is only
A 2ch but works and I'm not sure bout the receiver was thinking of starting there 3ch from
And old venom
And old venom
Well if you installed a hi torque servo then you probably need to add a BEC.
Quite often the BEC that is built in to the ESC is not powerful enough to run a hi torque servo and still power the motor.
Most people that I know run the Castle Creations 10 amp version.
It would be helpful to know which servo you installed and which ESC you are using.
On my first Honcho I ran the TowerPro Hi-torque digital with no issues without a BEC. I too would start with the Rec. but it may not be a bad idea to install a BEC just for the added peace of mind. Are you running Lipo? Maybe check to make sure all plugs are installed correct and tight...make sure also you dont have a loose wire on the ESC at all or the Battery. When you installed the new servo, did you center the servo before installing the servo arm? Im not trying to make you sound dumb, just throwing some things out there....I've been guilty of missing simple things myself
Got a new receiver and transmitter package .... Started with Putting the crystals in the new handle and testing and it was fine straight away thanks for all the help happy crawling
