Novak goat $#!T
#46
The bec you have is the right one. You can change it's settings with a castle link. It should have instructions on how to connect it. You just solder the wires to the battery connector on the esc side. Then plug the bec into the power/batt slot on the rx. Are you using 2 batteries or 1 with a y-cable? Just pull both of the red wires from the esc connectors and plug them into the rx on the channels you want to use for throttle. No y harness. Then plug the servos into the channels you want to use for steering. Use the radio to blend the channels and you won't need any y cables.
That's just one of a few ways you could do it.
A novak dig unit could be helpful too but isn't really necessary with your radio.
This is the bec that I have.
#47
That is just a pic of the BEC mine is new in the Bag
#48
In post 31 you said you had an airtronics 8 channel and post 33 you said you could blend them. I'm not familiar with your radio so I can't help you there. Some radios you can hook up to a computer and blend channels that way.
You hooked it up to a 2 position channel, that's why it didn't work. You need a channel with full control.
#49
#50
Ok guys I got the crawler to work just fine thanks to all who put input on my matter. Now I have one LIL problem and I can not fined the fix for it, My steering servos are both on one channel with a why harness I was thinking that when I connect them into one channel they would both turn left but one is turnning left the other to the right it is crabbing any input would help me very much
thanks, Guy's
thanks, Guy's
#52
