Go Back  R/C Tech Forums > General Forums > Crawler Room
(Help)SSD Wheels On Vanquish Phoenix >
Rate Thread
Old 02-08-2023 | 07:39 PM
Hectomilan's Avatar
Default (Help)SSD Wheels On Vanquish Phoenix
So I can’t seem to figure out what lock Nuts will fit on the SSD hub. The original SSD Hub that came with the wheels are zero offset and was rubbing on the portals so I bought the +6 offset to clear them the issue I am having now is that the vanquish 8mm nut driver won’t fit the hub on the +6 mm offset. Does any one know what nut or driver I can buy to install the wheel nuts thanks in advance!!
Hectomilan is offline
Old 02-09-2023 | 11:58 AM
Hectomilan's Avatar
any idea ?
Old 03-15-2023 | 03:12 PM
JayRC66's Avatar
Can you return the SSD wheels? I am using Methods. They fit just right.
Another solution is grind down the outside of the nutdriver until it fits.I am not impressed with F10 portals. You are very limited to what wheels you can use.
Good luck.
JayRC66 is offline
Old 03-17-2023 | 01:47 AM
sosidge's Avatar
8mm nut driver is for M5 nuts, you need a 7mm not driver for the M4 nuts which are the standard for 1/10th wheels. Is it a typo or were you using the wrong tool?
sosidge is online now
Old 03-20-2023 | 04:08 AM
Vanquish part number IRC0042
super thin wall driver
cul8tr is offline
