C4 Layshaft Slip
Old 08-29-2003, 03:37 PM
fatdoggy's Avatar
Default C4 Layshaft Slip
I've been running the C4 for about a year and the last few months the mid layshaft bearings has started to slip. I run the layshaft oneway completely loose and the standard diff up front. I used the setscrew as recomended on the Corallyusa website and it worked for a while but the bearings is still slipping, Is there a way to completely lock up the layshaft? so I can just put a front one-way in it.
Thanks.
fatdoggy is offline
Old 09-01-2003, 03:23 PM
black-knight's Avatar
to lock up the oneway on the layshaft, we use to do the following:
1. file a flat on the layshaft
2. tap a grub screw through the oneway down on to the flat created on the layshaft.
this would then make for a solid layshaft setup.
black-knight is offline
Old 09-01-2003, 07:11 PM
fatdoggy's Avatar
Ahhh, that's a great idea. Thanks black-knight.
fatdoggy is offline
Old 09-03-2003, 08:39 PM
fatdoggy,
Check out the Corally USA site under the Tech Info section for this tip as well as some others for the C4.1
JANTLE is offline
Old 09-03-2003, 09:44 PM
fatdoggy's Avatar
JANTLE - Thanks.
fatdoggy is offline
