Go Back  R/C Tech Forums > Commercial/Retail Forums > Banzai Hobby
Acuvance OP-15027 LED Control Unit i-Light >
Old 08-07-2015, 09:56 PM
Company Representative
Arrow Acuvance OP-15027 LED Control Unit i-Light
By using TAO-II, you can now adjust the color of LED, light timing, strobe effect etc from TAO-II wirelessly.
Linked with Controller throttle, Light will change depending on how your machine run.
Further more, Head Light and Back Fire Light is using Full Color LED, meaning you can adjust LED using same LED light. You do not have to change the LED lights!
Important:
To operate i-Light you require following software updated to your ESC, TAOII and Brain Unit.
AIRIA: Ver 4.2
TAOII: Ver 1.3
Brain Unit: Ver 2.0
BONUS FREE Part!!!
Brain Unit Update USB adaptor (Acuvance OP-15025) worth JPY2,500 to updated Brain Unit comes with Free with 1st production!!
Basic Kit include:
LED Control Unit (size31x30x10mm, 7.4g) (x1)
Brain Unit Connect Cable (x1)
Head Light Full Color LED (x1: 2 lights in total)
Brake Light LED (x1: 2 lights in total)
Back Fire Full Color LED (x1)
LED Light System RX split cable (x1)
Feature:
Multi Lightning Dress Up System (MLDS)
By using TAOII you can set up LED lighting by bluetooth wirelessly.
Head, Brake and Hazard Light is designed turn on / off softely like real car.
LEDs can be set up with your controller throttle to adjust
+ YouTube Video
Head Light:
Using full color LED Light. Can choose from 15 colors inc. turn off option.
You can choose 2 colors to blink. There are 225 patterns to choose your LED lighting patterns!
You can choose 10 different type of LED light blinking.
When your RC car stop, you can choose 4 different timing till LED turn off.
Brake Light:
You can set up when you apply for brake to turn on the LED
You can adjust the timing between brake ~ neutral
You can adjust the timing till when your rc car stop till LED light turn off
Back Fire Light
Hazard Light (Orange LED) Not included with Basic Kit
You can adjust LED blinking speed and turn off timing.
You can set up when car stop hazard light comes on and adjust the timing till hazard LED light turn on.
Back Light: (White LED) Not included with Basic Kit
When you reverse the car White LED turns on.
BanzaiHobby is offline
Old 08-10-2015, 02:09 PM
JatoTheRipper's Avatar
That's pretty cool!
JatoTheRipper is offline
