Rony Racing VORG F1 Conversion Kit!
Company Representative
Top Spec F1 Conversion Kit!
Available
VO-0001 VORG Conversion Kit Type1 (with motor mount)
VO-0002 VORG Conversion Kit Type 2 (without motor mount)
Conversion Kit for Tamiya F103, F104, TRG112
** MADE in JAPAN**
High End Performance VORG Conversion Kit.
Main Chassis:
Low gravity dessign 2.5mm thickness Carbon Main Chassis. Perfectly calculated chassis width will let perfect chassis roll.
Upper Deck:
Using front and rear separated type. Front rigidity can be changed depending on the course and your set up.
Designed to be able to use both normal LiPo as well as short LiPo. Short LiPo can be positioned either front or back end.
Roll Shock System:
Left and Right movement is separated by Roll Shock System.
Spring will push nicely off your machine after rolling has finished.
If you are looking for Winning F1 Chassis, do not miss this opportunity!
Wide variety of setting is possible with this Conversion Kit!
Set include:
* Motor Mount
* Friction Damper 2pcs
* Resin Side Bar
* Separated type Upper Deck Type
* 2.5T Main Chassis
Require F103, F104 or TRG112, specifically
* Ball Bearing
* F&R Wing
* Diff Set Up
* Front Suspension
* Servo Mount
* Servo Saver
* Pitching Damper
* RC System
* Body
* Body Mount
Available
** MADE in JAPAN**
Main Chassis:
Upper Deck:
Roll Shock System:
Set include:
* Motor Mount
* Resin Side Bar
* 2.5T Main Chassis
* Ball Bearing
* F&R Wing
* Diff Set Up
* Front Suspension
* Servo Mount
* Servo Saver
* Pitching Damper
* RC System
* Body
* Body Mount
