Kyosho Snap 720EP
Rate Thread
Old 09-04-2011 | 06:52 PM
Company Representative
Default Kyosho Snap 720EP
Kyosho Snap 720EP now at Banzai Hobby
Fully assembled pre-colored hull of FRP over 47Km per hour was achieved ●.
Pre-mounted water-cooled brushless motor ● 28mm size value of 2636 KV.
● 75A (90A moment) class high-power water-cooled ESC as standard equipment.
Can fine-tune the position with an aluminum bracket Bridge Industrial drives ● tilt adjustment mechanism.
Waterproof rubber boots ●, aluminum servo mounts, carbon fiber 3 blade screw nylon (with spares) attached.
The shape of the hull design has its own type V, both the superior cornering performance and high-speed glide performance!
Racing amazing performance, easy to enjoy in the PIP kit!
Excellent performance, the V-shaped hull that stable high-speed turning performance, hull shape in the second half gave the shallow glide angle made ​​by the original hull multistage step further, achieving an ideal performance racing. Excellent performance while skating, the performance wearing a unique swivel-type hull V "Snap 720BLS" is. + 4 - equipped with variable degrees bracket -4, without wasting power, showing the race to be converted efficiently into thrust. The water-cooled brushless motor and a large water-cooled ESC already installed, the maximum speed achieved over 47Km per hour. In the factory and almost finished, the hull is made ​​of high accuracy and high-strength FRP. Painted bright. And giving a glossy surface finish quality feel stuck in yet. Drive bracket and necessary tubing and aluminum Stan driving propellers, pre-mounted water rudder. Shaft has been achieved as the Wire-low noise, low vibration drive. Joy not only to run, enough to meet all the genuine sense of satisfaction that you own. Transmitter and receiver and servos, the PIP kit Provided the battery only take you to the exciting world of racing water.
Kit Contents
Pre-water-cooled brushless motor ●
● Fully assembled hull color (already installed)
Water-cooled ESC ● (already installed)
● clear waterproof tape
● gridiron
● Japanese ● Spare propeller manual
<Required to Bridge Industrial>
● Servo 2ch1 their radio /
● 3-cell 11.1V-2, 100 - 5,000 mAh Li-Po battery specification Super plug (recommended: ORI60071 Avionics Li-Po4000-11.1V35C)
Batteries for radio ● ● Li-Po battery charger
Within the servo can be installed size 40 × 20 × 36mm ●
Within the battery can be installed size 150 × 50 × 36mm ●
http://banzaihobby.com/index.php?mai...ducts_id=11609
BanzaiHobby is offline
