Yokomo DP-DP8 Drift Package Basic
Company Representative
Basic version of Yokomo Drift Package. Reasonable drift package chassis set. Ideal for beginner or base chassis for the expert drifters. Can be upgraded as your skill level goes up as you can use Drift Package hop-up parts! Including metal ball bearings for smooth drifting!
Features:
* Shaft Drive Fulltime 4WD Chassis
* Composite molded chassis
* Double wishbone suspension
* Fixed alignment tie rod
* Rigid Axle (F&R)
* Front Universal Shaft & Rear Dog bone
* Front Urethane Damper & Rear Bumper
* Aluminium Die Cast Clamp type motor mount.
* Ball Bearings
Require, Radio gears with ESC, Batteries, Charger, Motor, Body,
Features:
* Rigid Axle (F&R)
* Ball Bearings
