HC Friction System for Tamiya F103 & F104 by G-Style (Team Bomber)
G-Style TB40008
Team Bomber HC Friction System for Tamiya F103, F104
HC (High Capacity)
Friction Plate and Friction Pad are 2mm wider than standard kit.
Friction Plate, Pitching Bottom side has been modified and optimized when bottom out.
Friction Pad has been made with special Teflon material an smooth action is assured without any Teflon tape.
By installing HC Friction System, stability and cornering speed will dramatically increase as well as less maintenance and more setting availability for your F1 RC Beast!
G-Style TB40008
HC (High Capacity)
