-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Basic 1/5 setup (https://www.rctech.net/forum/australian-racing/987769-basic-1-5-setup.html)
mini4350 05-17-2017 12:27 AM
Basic 1/5 setup
Hey guys new to 1/5 onroad, Iv got a car and looking for some basic setup information to get an idea of where to start?
Iv been racing 1/8 GTe but not sure what shock and diff oils, camber and toe to start with on the 1/5.
Any help will be much appropriated
Craig1 05-17-2017 01:52 AM
Harm have a setup book available for down load on their site in the download section. I don't think it states a specific oil, spring, camber etc, more of an overview of what particular things do. Sort of like the Xray book.
Or if you check the sites of most of the popular brands you should find a setup sheet.
Even if one doesn't apply to your car in detail they should at least give you a heads up.
magnuts 05-17-2017 03:17 AM
Alternative is to talk to drivers at your local track, see what set up they have, and copy. Most will be more than happy to help.
Test Driver 05-17-2017 07:51 PM
It depends a bit on what car you have also. Some cars like different settings. A basic idea is, front shocks - 8-10000, rear shocks 2-5000. Diff, this depends on what diff you have. Front toe 1.5-3deg toe out each side, 0 to +2.5 camber up front. Rear 2.5-3deg toe in. 0 to -3 deg camber.ride height between 6-10 depending on how bumpy the track. Sometimes higher. Generally the back about 1mm higher than the front.
Hope this helps
mini4350 05-17-2017 10:25 PM
Hope this helps
Hi test driver
I have the redcat XR EP Pro 1/5 and it comes with standard diff gears like an 1:8gte. Cheers heaps for your basic info, that's all I was after
Test Driver 05-19-2017 03:31 AM
with gear diff, just put thick diff oil in it like the 1:8gte. thickness and quantity dependant on grip available. more grip, thicker oil etc
