Tips & Tricks
Old 11-09-2005 | 05:52 AM
  #31
Paladin's Avatar
So if i have this straight....
I have a almost new set of RP40's I want to remove from cracked rims. I want to save the tyres, I dont need to save the rims.
What is the BEST method, please?
Paladin is offline
Old 11-09-2005 | 01:36 PM
  #32
soc123_au's Avatar
Soaking the rims in acetone works for me. I have tried boiling them & just made a mess.
Foam soaked off in acetone can be reused. If you chunk a tyre & the rim is still good you can get rid of the foam & then take the good foam off a rim that had had the centre punched out & reuse it. Re glue the good foam to the good rim with shoo goo. I also soak the foam off my worn out 1/8 rims & reuse on tourers. The 1/8 to tourers I use as practice tyres.
soc123_au is offline
Old 11-09-2005 | 01:37 PM
  #33
soc123_au's Avatar
Acetone will get them off, but I think it may effect the rubber.
Old 11-09-2005 | 08:43 PM
  #34
Paladin's Avatar
yeah thats the rub, I want to save the rubbers as brand new(ish).
Paladin is offline
Old 11-10-2005 | 02:02 AM
  #35
Jack2's Avatar
Joe, there is some stuff called "Flash back".... You can get it from most hobby shops. I have seen people remove tires from rims using that.
Jack2 is offline
Old 11-10-2005 | 03:25 AM
  #36
Paladin's Avatar
Hey JAck,
Thanks, will wonder down to LHS and see how mucho dolars.
Paladin is offline
Old 11-10-2005 | 03:33 AM
  #37
Jack2's Avatar
Joe, its about $8 a bottle. Same size as regular "Track Flash" - Good tire glue
Jack2 is offline
