Airbrushing and Art
#691
Leaving the excess flashing on the shell gives you something to hold on to while tipping and rotating the shell as you paint.I've tried both ways and after a few finger smudges always trim afterwards.
#693
Locally a shop in Minchinbury sell everything you need. If money is not a problem. The link below
http://www.airbrushshop.com.au/shopm...=Airbrush+Kits
I got my airbrush overseas as I save atleast $150.00 so I got mine in Ebay. The Iwata HP-CH seems to be the best value. It cost me AUS$250.00 delivered and comes with a few extra bit You can buy an Airmax Compressor for under $200.00 in Hobbyco. You will still need paints and another $100.00 to cover for hose, water trap and other bits.
#694
I got my airbrush overseas as I save atleast $150.00 so I got mine in Ebay. The Iwata HP-CH seems to be the best value. It cost me AUS$250.00 delivered and comes with a few extra bit You can buy an Airmax Compressor for under $200.00 in Hobbyco. You will still need a paints and another $100.00 to cover for hose, water trap and other bits.
#695
I highly recommend the Iwata HP-CH Mac Valve airbrush, smooth to use and is the best airbrush I've used for fine line work. Try "Lewis online" store on ebay, approx $250 landed rather than the $400 you would pay here. The other thing you might want to look at is what paint medium you will mainly use, (Acrylic or Laquer based) as using the same brush for all paints, can end up with blockages and premature wear and tear. I personally use 3 brands, Iwata HP-CH Mac, Passche VL Pro and Apollo Richpen 112b all good but the Passche is probably easier to get spare parts for through your local hobby store.
I hope this info helps in your choice of brush
Cheers Mavrik .
Cheers Mavrik .
#696
Hi all,
Am going to try painting a new shell using Parma Faskolor with an airbrush. Last time i tried this paint it did not really take to the body shell. Made sure that i did not put too much on each coat, and with plenty of time to dry between coats. Even after drying for days you could easily put a scratch in the paint. I ended up backing using a tin of Tamiya paint which helped reduce the amount of paint being taken of.
Any ideas or suggestions. Anyone else have this problem?
Thks
Ryan
Thks
Ryan
#697
Originally Posted by SSS Racing
Hi all,
Thks
Ryan
Thks
Ryan
order of operation;
1)wash body with detergent, and scrub it (like washing a plate) with a wire spong
2)rinse well
3)paint
4) dry each paint coat with a hairdryer
5) always back when finished the entire body with either a sealer coat of tamiya white, pactra white (the can versions) or with pactra airbrush paint white
done
#699
Originally Posted by TomB
order of operation;
2)rinse well
3)paint
done
2)rinse well
3)paint
done
Yeah i did all of the above with the exception of scrubbing the body with a wire spong. Then backed it with Tamiya white which helped to prevent the scracthing. The Parma paint just never seemed to bond with the body from the beginning as well as Tamiya paint does.
Anyhow will try the wire sponge and hopefully it helps. Thanks for your advice.
Cheers
Ryan
#700
i use spaz stix surface pre- prep (90059) seems to work fine
#701
#704
looks rather angry.............u forgot the dreadlocks,looks good Tomb, you r the master
#705
Nice work Moz and TomB, keep it up guy's. It's good to see other peoples work for inspiration.
Here are a couple more I've done lately.
Cheers Mavrik
Cheers Mavrik
