Drive problem
Old 02-15-2014 | 09:07 PM
Default Drive problem
I have a 3 year 4wd old hsp xstr pro with major drive issue.
I want to try and fix cheaply and then sell, so i can buy a real car.
Drives on right side is fine, but left side [ front and back ] is not working properly.
At low revs i have no drive at all on left side only. At high revs left side is driving at about 30% only.
I pulled gearbox / rear diff apart cleaned and cant find the problem.
Not sure what the problem is maybe gears or bearings.
yabbie killa is offline
Old 02-16-2014 | 02:42 AM
Start simple.
Work back from the wheel nuts through to the ultimate drive.
Probably could be just a pin missing on one of the hex's where the wheel attaches.
Craig1 is offline
Old 02-16-2014 | 07:58 PM
Thanks craig. That did the the trick.
Dam hex's
