My TT
My TT
I have a TT01 and run it on the tracks against my cousins and mates, its fun and reliable, might upgrade in the future to a better chassis, but i was wondering weather some of the hopup options do anything for the car whatsoever.
e.g the aluminum propellar shaft, is the aluminium better than the stock plastic one?
btw the only mods i've done to it are sports tuned motor, 22T pinion and ball bearings.
I figured all that other crap like metal arm set and carbon uppper frame dont do anything as none of my plastic is breaking or melting
Thanks, ray~
Thanks, ray~
hi i have a TT-01 and i run a 25 pinion with a 55 sur and it does good but to modify the hole on the motor mount ill show you a site it tells how to do it http://www.kawadamodel.co.jp/partsli...6module_e.html hope that helps
no the car is stockest of the stocks, all plastic, but it runs quite well.
Thanks kid appreciate it btw, if i get a different spur gear would i have to change the piece that covers it, or is the size of the 55T same as the stock 61T (diameter wise)
The aluminium prop shaft do help...esp if you're going to run something like a rebuildable stock. I find that the stock shaft will warp as it rotates at very high speeds.
