3Racing F113
#77
Also check the mono o ring spacer that sits under the o rings, as they sometimes have small molding "flash" on the face of the spacer which puts more pressure on the o ring.
Best off to carefully sand the o ring spaces flat, which helps to also stop the shocks from leaking because the o ring then sits flush up against the spacer.
Hope this helps.
Hope this helps.
