-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Need Some Help With An ESC (https://www.rctech.net/forum/australian-racing/593675-need-some-help-esc.html)
Caydenn 01-30-2012 11:59 PM
Hey there all once again I need the wisdom Of the RC forum. I have been offered a LRP SXX to buy. Now this ESC will be used initially for 21.5 With My LRP X12. And then will also be used in 17.5. It is between This ESC or The hobbywing justock (I have been offered one for the same price as that ESC <--).
Any Important Info I should know about the receiver please let me know.
All Help Is Appreciated
Regards
cruisecontrol 01-31-2012 01:06 AM
If its the LRP SXX make sure its a V2 if your running off road. For on road, ignore :D As far as the reciever goes shouldnt be any problems as far as i know of
Caydenn 01-31-2012 01:24 AM
@Cruise I think its The version 1 it would be for 1/10 On Road touring Car. So you Reckon Stay Away from it?
chrisk 01-31-2012 03:16 AM
The just stock is fine in 21.5 as most on road now run blinks mode, but if you move to 17.5 and want boost you can't with the just stock.
Can comment on the LRP
danjoy25 01-31-2012 03:24 AM
both not good when you go up to 17.5t. Get a Hobbywing Extreme or 120amp version esc. Speedpassion or Venom 120 amp versions will also work.
hacker 01-31-2012 09:04 AM
the sxx is a great speedy for offroad, or even a mild mod touring car.
for your onroad application(21.5/17.5) a tekin or hobbywing is your best bet.
Dadaman 01-31-2012 05:42 PM
+1. I use a Tekin RS Pro for 17.5 boosted on road. LRP SXX V2 for 4wd off road stock. The powerband on the Tekin doesn't make for a good Off road 2WD speedy, so I use a Hobbywing Xtreme for that class. Never tried the SXX V2 in 2WD. From all accounts, all the fast guys run Hobbywing.
Caydenn 01-31-2012 06:43 PM
Guys Thanks For The Answers. I ended Up going with a Hobbywing Justock for my 21.5. I will get myself A new ESC when I go into the 17.5 Class :nod:
Dadaman 01-31-2012 08:44 PM
Prob a good idea. From all accounts, the V1 of the SXX's firmware can't be upgraded like the V2's can.
