Alternatives to Shoo Goo?
After finding that my tube of Shoo Goo is now Shoo Rock, I went out to buy myself a new one. Unfortunately I can't find it anywhere in Perth, so I'm looking for an alternative that I can get from Bunnings/SuperCheap etc...
Any help?
Cheers.
Any help?
Cheers.
Thats where I found mine after trying your mentioned stores..
got mine in rebel sport.
Hi Dan
If all else fails you can order from here
http://www.ausport.com.au/catalogue/c4/c91/p488
Cheers
Cheers
I get my shoo goo from any Rebel Sports otherwise try Bunnings and get Liquid Nails Clear comes in a tube like shoo goo and works just as well and about the same price..
Most shopping centres over here have a Kiosk to cut keys, repair shoes, engraving ETC. Thats where I get mine from.
Make sure you use shoo goo or Clear liquid nails in conjunction with Gyprockers or plasterers tape which is meshed and sticky on one side it really strengthens any body.. like fiberglassing for lexan
Here's a link to Stanbridges, looks like they have it in stock.. ** seems i missed their "out of stock" notice
http://www.stanbridges.com.au/shop.PT12
-Mark
Repairs
G'day Cobba, a couple of other fixes you may or may not want to try.I use 2 methods, 1, run a light trail of CA along the crack then sprinkle corn flower over it, repeating this until it covers the problem spot. Cheap and quick, This method does not add much weight. 2nd method: Use the brown sports strapping / bandage, it's difficult to get it to stick at first, some heat from a hair dryer helps, but once it is in place soak/ wet it with CA.the ca glue sticks it well to the body and turns it hard, offering good strength. I put small bosses/ gussets around the body post holes to add some durability and it lasts as long as original new body would doubling the life of said body. Hope i have given you some help, c ya.
Did you try K-mart I have got that sort of stuff from there hey i've even been able to get a two part liquid metal for gluing magnets in
Ex west ozzy
