roll out
Old 10-11-2004 | 07:26 AM
Default roll out
hi every1,
jus wondering, wats "roll out"...ive seen it mentioned a few times in different threads and have no idea of wat it means...seems important though...is this pertaining to both nitro and electric cars?
thanks for any feedback and of any useful explaination!
reckLEss is offline
Old 10-11-2004 | 12:19 PM
fatdoggy's Avatar
You use rollout if you run foam tires.
(Tire diameter x 3.14) / (Spur/pinion x internal gear ratio)
It's a calculation that tells you how far the car moves with 1 revolution of the motor. You can also use a tape measure and just turn the motor 6 knotches(1 revolution) and you'll get the same rollout(just take up the slack in the drivetrain when you measure).
fatdoggy is offline
Old 10-11-2004 | 11:45 PM
nerdling's Avatar
check out:
http://www.actmcrc.org.au/technical.htm
also has a roll out calculator, and a print function is ont he way
nerdling is offline
Old 10-11-2004 | 11:50 PM
danjoy25's Avatar
Default Re: roll out
Originally posted by reckLEss
hi every1,
Its mainly for Electrics I think.
danjoy25 is offline
