540 Run-in Methods
the optimal run-in is to run the motor of 4 cells for 2 mins then of 2 cells for 4mins. but i heard thats for stock and mod motors. so what i do is connect one of my old half charged 1400 batteries packs to the 540 motor and run it in water for about 2 mins. the clean it out with motor spray and the oil it and it will runn really well.
Hook it up to. 240 Volt for about 1 hour.
It May Work after.........
Jokes.
Just run it in water. Sometimes i put Toothpaste at each end of the motor. so it slowly gose into the bushs when it running.
Cheers
Jokes.
Cheers
Originally posted by Pro4
shutup murfy...
just backing u up
shutup murfy...
just backing u up
yea with the motor break-in i have also tryed spraying som WD-40 into the water and it does make the motor nice and smooth but it is a bit messy.
yea my trick with the break-in is once you have ran it in water for 2mins spray the inside of the motor with WD-40 the run it in some new water for a futher 20 seconds the spray with motor spray and oil.
not much to remember
i know
Originally posted by danjoy25
Might try the Holy water in the coming TCS as I will be needing all the help I can get. Where can I get one?
Coxy.
