Paint job tips
Paint job tips
Hi I'm just about to by a new body shell
and paint it but I want to do something
different. does any body have some tips
to paint the body and how to put sticker
on curved eges easier. I tried it before and
mess up big time
tc3=speed
mess up big time
tc3=speed
Stickers
To put a sticker on ,spray the body (where you are putting it), and then spray the back of the body with soapy water in a spray bottle.
This way you can move it in to position.
Then roll your finger from the in side out, to get rid of the air bubbles and wrinkles (and no this wont work on old peoples faces)
Have a practice go on a coke bottle, and see how you go.
Good luck.
Good luck.
You can also fade colours into each other. that can end up with a cool effect.
eg. A red can fade into a yellow.
To apply this effect, spray the shell but slowly reduce how much you spray as you move further into the shell.
Next, get another colour and spray from the opposite end into the shell. Because you haven't ended suddenly with the first colour, the paint will "Blend" together.
Note: This works best if the paints are still slightly wet and you have two colours that contrast and work together. It also works well with Flames.
Hope ya get a cool effect!
Or, if you've not got the patience or skills to do a good paintjob like me, do as I do - publicly acknowledge the fact that your art/creativity skills suck more than Monica Lewinsky, and either
a) live with a 1-colour shell, or
b) see your local track's best artist and shell out $50ish for a paint job from him/her.
Either works.
-Scott
Either works.
-Scott
a good effect for people spraying with cans is ripping up some masking tape (3m blue type or thick white type...only use 3m) and spraying over it. then placing a colour as the rip. looks good.
i'm gonna do a body like this soon i'll post it.
you also get a cool effect on your car body if you give it to wombat
umm i have a tip... always remember to apply the window masks before applying paint...
Also always check to see if there is protective film on the inside of the body LOL. don't laugh it happened to me not so long ago. Bloddy thing took me hours to mask up
Coxy.
Coxy.
Coxy.
Coxy.
it's sometimes funny seeing the newbs race their cars with white windows. i did the same mistake with my first body...lucky i realised in time and was able to take it of with wd40
Originally posted by VenomWorldOrder
hahaha i'd say sucked in but that's just cruel
one thing that i have to say to anyone wanting to spray more than 1 or 2 colours. TAKE YOUR TIME!!! (trust me it helps)
white and green
white and red
Re: Paint job tips
mess up big time
tc3=speed
mess up big time
tc3=speed
when you feel you know what you are dioing go onto your own paint mask designs
Good Luck
cool thank guys for all these tip, got any more
The biggest tip would be to "know what end-result you want".
Design and how you plan out the painting steps is important. Usually dark colours go on first, lighter colours next. (Even write down your colour sequence like a recipe if you have to.)
Depending on what you've designed, you can either get away with no masking... or go totally crazy on the mask job.
Here's examples of both extremes:-
