Need some setup help for SERCCC Dandy Buggy
New to Nitro buggies (did run electric onroad) I would appreciate some help in buggy setup...
Currently run an inferno 7.5 with Kanai shocks (blue medium springs) 40wt/35wt F/R oils, anti sway bars with proline knuckle tires -2 degree camber with a little front toe in and 3 degree's toe at the rear. Diff oil is 3/7/1. STock engine. Currently have a 17degree caster and have just ordered 20 degree hub carriers. Just can't seem to get a good run down the back straight or the front without bouncing all over the god damn place ! Cornering My first thoughts are the knuckles have too much grip in the corners thus I can nearly flip over.....(I do understand i have brakes!) Suspension I just don't know I did start out with really soft springs which was worse than the medium springs I currently run however just can;t seem to get the car sitting well under speed. Help! Can you suggest tires, shock preload and shock oils that may work for this track. or any other suggested tuning parameters that may help our inferno |
| All times are GMT -7. It is currently 10:15 PM. |
