-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Set Ups (https://www.rctech.net/forum/australian-racing/33900-set-ups.html)
STILL BURNING 02-19-2004 04:19 AM
Set Ups
:flaming:
Could someone please give me some setup tips and gear ratios/rollouts for a TC3 running ( the car set up at present is1500 grams, 33000mah batteries, 2degrees to in front 3 degrees rear, 37shore fastline tyres) for northside, lithgow, castle hill and illawarra race way. Thanks.
MrEs 02-19-2004 05:07 AM
clean and oil your bearings. keep your disfs lean/oiled and running free.
Andrew_XXXs 02-19-2004 12:48 PM
Definitely for Castle Hill and probably for Northside you will need rubbers. The word around the town is Sorex 28's for Northside and Sorex 28's (24's if its cold) or TakeOff 27's for Castle Hill. Medium B Sorex insert for both I think...
Holden Lion 02-20-2004 05:32 AM
I have seen the layout and surface of castle hill before. Is the northside track similar or is it differnt, if so what are the differences?
Andrew_XXXs 02-20-2004 12:08 PM
Northside is nothing like Castle Hill. I haven't seen their new track layout but last time I went, the track was much bigger, not nearly as tight and generally a higher speed track. The surface is blacktop not concrete so grip is different also. If your planning on running the club challenge I suggest you do a meet there before the club challenge day. I think a few of us are planning to do this as well...
Holden Lion 02-20-2004 06:15 PM
so would foams work at northside or is it a track suited much more for rubbers?
Dragonfire 02-20-2004 06:22 PM
Foams work but rubber is faster at northside. Foams don't work at all at castle hill.
Holden Lion 02-21-2004 01:19 AM
ok thanx for that!;)
