Ball Diffs
Old 02-09-2004 | 03:39 PM
Default Ball Diffs
Can someone advise me is there another sort of ball diff that will fit the Evader St.I am sick of these plastic crap.I want a ball diff that will last whilst racing. Open to any suggestions...
By the way the Evader is Nitro, not electric......
EVADER RACER is offline
Old 02-09-2004 | 03:48 PM
contact's Avatar
have you boiled the plastics?
30min then let the parts and water cool together that can often help...
we put a kontronic BL motor in an evader truck... it wasnt the gears that gave way! the rear of the truck got torn off when it polaxed the illawarra big jump retaing boards...
contact is offline
Old 02-09-2004 | 03:58 PM
OldSkool's Avatar
Default Diff
Because the Evader is a near copy of a Losi XX try a diff out of one of those.
The XX-t and the Evader ST have parts that fit each other.
Horizon own Losi and Duratrax ,I think?
Good luck.
OldSkool is offline
Old 02-14-2004 | 09:22 PM
Default Ball diffs.
Try tighting the diff. If it's to loose like my ex it will squeal but do to the nitro you can't hear it and you stuff your diff.
The instructions detail this and maybe you should read again.
I have never had a problem and race on and off road.
FullySikDuraMic is offline
Old 02-16-2004 | 02:16 AM
Default stealth diff
word has it that the old stealth diff fits with a little bit of work with the dremel(around the outdrive holes) if you can break one of these diffs then your doing something wrong
gkp5569 is offline
