question for Mars R
Old 11-26-2003 | 12:24 AM
Franky's Avatar
Default question for Mars R
hi everyone,
i am using a Mars R. have a hydro pack. the jet is same as the sys for the receiver pack. red in the middle. black in the side.
just want to know the wiring of the hydropack. is it different from the receiver pack wiring? plug in , there is no power. so if anyone have such experience. pls let me know..
many thanks.
Franky is offline
Old 11-26-2003 | 01:30 AM
NR's Avatar
NR
Default Mars R
Im not really sure however i wouldnt play around and connect things if you aint sure cause i can ssure you that it would be an expensive mistake.
I do know one thing though when charging the receiver pack by using the Jack on the radio. Dont just use a normal Charging Jack because on the mars R it is reverse. Negative is positive positive is negative etc. So be carefull.
I suggest sending an email to Ko Propo
www.kopropo.com
NR is offline
Old 11-26-2003 | 02:31 AM
Franky's Avatar
yes. i reverse the red and black. it works fine...
Franky is offline
