WHAT TYRE's for CANBERRA challenge cup
hey I know we need to run foam tyres at the challenge cup in canberra because its on carpet
but what sort are the best?? like i,m clueless
I have no idea about foam tyres so if somebody could tell me what i need that would be awesome PLZ HELP!!!!
THX Gazza
THX Gazza
is that the thickness of the foam?
or the mm of the rim???
like i sed i,m srsly clueless
G'day Gazza,
When you go to purchase your foam tyres, you can ask for foams for electric racing. These will be 26mm in width and then you ask for the shore/compound which is the hardness of the tyre. The harder compound is run on the front. The foam tyres come as a front and a rear. I purchased the ATS brand foam tyres for the ACT Titles.
For front as per Rod's post:
42F or 40F compound 26mm width
37R or 35R compound 26mm width.
You can get these tyres in 30mm width, however these will need to be trued to to the correct width.
Hope that helps.
Later
Calvin.
Hope that helps.
Later
Calvin.
ok thx man that helps alot =]...
i,ll try find some tyres now
