Corally Phi Thread
#526
I ran a Corally 07 in 540 pro in the later part of 2009. Most of the year i run a one way instead of the spool. I ran the car at the Metro Masters and it drove very nice. The car goes very very well at Bendigo.
When i ran the interclub at Boronia i had my TRF 415 with a oneway and it went fine. My Corally 07 would have gone even better if i had run that.
I will check the setup and let you know
#530
#532
i have the kawada like this one
http://www.rcmart.com/catalog/rc-spu...t-p-16083.html
#534
KAWADA are awesome....thats what i have always used...so close to the originals anyway....also i use robinson racing aluminium pro pinions....
but you cant go wrong with the KAWADA PINIONS either...
#535
Can anyone tell me if the TA05 spool and/or oneway fits in the Phi.
BTW I picked up a "pre owned" 08 Phi and after a strip down today, I have to admit that the build quality is exceptional. Time to put it back together
#537
That is for "super short wheel base" set up. I can't remember detail but rear shock bolts on other side and played with wishbone spacer to make uni straight. Also you'll need a lot of diff spacers. If I pulled out my PHI parts from some where in my room, I might remember few more things to make this happen.
#538
Thanks Hiroshi, the car I got has a front and rear ball diff.
If anyone has some Phi parts they want to off load (prefer NIP), let me know via PM. Wish list is belts, front spool or one way & body posts.
No rush as I wont be using it until later this year.
