Corally Phi Thread
Old 06-22-2009 | 08:17 PM
  #406
OLD 69's Avatar
Company Representative
Originally Posted by Sherif
you can use the 1st PHI front bearing holders by the look
Yes they will fit straight in. What i have done is put a small drop of glue to hold the bearing in tight, just becarefull not to put too much...
Regards
Ari
OLD 69 is offline
Old 06-27-2009 | 06:16 AM
  #407
mazmo's Avatar
Default Corner speed
Guys,
Got an 'old' Phi ..... what would be the best set up change to get more corner speed.
Any suggestions appreciated
Thanks Alan
mazmo is offline
Old 06-27-2009 | 06:19 AM
  #408
B4james's Avatar
Hi Mazmo,
What exactly are you looking for when you say corner speed, is it corner entry speed, mid corner speed, exit corner speed ?
What is the car doing now ?
B4james is offline
Old 06-27-2009 | 06:48 AM
  #409
mazmo's Avatar
Originally Posted by B4james
Hi Mazmo,
Thanks B4james,
Mid corner speed the main priority ... then entry corner speed.
The car is noticeably bogging down mid corner ... a little on corner entry too. Apart from that ... the car is planted.
Cheers
mazmo is offline
Old 06-27-2009 | 07:05 AM
  #410
B4james's Avatar
What track are you running at and can you post up or PM me the basic set up you are running at the moment
B4james is offline
Old 06-27-2009 | 11:42 PM
  #411
B4james's Avatar
Alan, you have returned PM
B4james is offline
Old 06-28-2009 | 02:11 AM
  #412
s.nicholson's Avatar
Hey just ran new car today, won the event against other drivers on foam tyres and much more tyres, i was running on the sorex tyres for the nats.
s.nicholson is offline
Old 06-28-2009 | 04:21 AM
  #413
B4james's Avatar
What are your thoughts Simon on the car on our tracks compared to at the Reedy ?
What track was it at as well ?
B4james is offline
Old 06-28-2009 | 05:45 AM
  #414
mazmo's Avatar
Thanks James
mazmo is offline
Old 06-28-2009 | 04:18 PM
  #415
yes car was still very good, I am running completely different setup to wat i was running at reedy. Im trying a more common setup with softer springs not hard like i use to run.
Old 06-28-2009 | 06:28 PM
  #416
B4james's Avatar
Simon, You have PM
B4james is offline
Old 06-28-2009 | 08:41 PM
  #417
Simon, You have PM
Pm answered, just post in this thread so that every1 can read answers to questions and tips and tricks
Old 06-28-2009 | 09:03 PM
  #418
OLD 69's Avatar
You are smarter than you look champ
OLD 69 is offline
Old 06-28-2009 | 09:57 PM
  #419
Hi Simon,
Finally got a set of Tamiya shocks built up this weekend. Used 3-hole pistons and Corally 5.8 mm ball cups on the shock shafts.
Do you use the Corally parts on the Tamiya shock shaft? Meaning ball cups and ends.
I probably will not get to do any testing with these shocks until next weekend.
Thanks.
Bill
Still Bill is offline
Old 06-29-2009 | 12:40 AM
  #420
Originally Posted by Still Bill
Hi Simon,
Thanks.
Bill
Yeh i use corally parts on the shock shafts
