Car Setup
Hello guys, i was wondering what setup you ppl use in eastern creek for electric TC stock:-
* Tires: Brand/Comp * Rollout * Body I assume you got diffrent setups for summer and winter so can you plz help us out, i was planning on using jaco and ellegi tires but dont really know what compounds to get, i ran there during meca 1 using 40/37 was ok, anywayz give us some feed backs. |
Set Ups
I'll be interested in this answer too. Also, any suggestions for rubber???(sorry to semi-hijack the thread :) )
Atomix - You stole my avitar;)
Originally posted by JohnA Atomix - You stole my avitar;) |
Actually I liked yours better than mine so I've just stolen it!
Set up for Eastern Creek
Not a lot of help being offered here. Maybe there's speed secrets we're not to know about ;)
Personally, I'm running Eagle 35s on the rear and 40s on the front. Rollout with a CORE stock is about 30.5. Forgot to compensate for tyre wear last club day and almost got eaten by a flying EVOIII! Still good enough for 21 lap 5.02 though. Won't make the same mistake this week. Body is the ubiquitous Stratus. Hope this helps. Scotty |
The good thing about foams are that they pretty much all work. Personally i prefer UFRA and Ellegi, mainly because of price, but wear is also very good ( any gas car based foam is good). Stay in the area of 35-40 shore. i generally run 40f and 40r, with 37f if i want a bit more bite.
Stratus is pretty much the standard in touring car racing, with a few Afla's thrown in. not sure re gearing a stock although 30-34 depending on the motor |
Re: Set up for Eastern Creek
Originally posted by ScottyP Not a lot of help being offered here. Maybe there's speed secrets we're not to know about ;) Personally, I'm running Eagle 35s on the rear and 40s on the front. Rollout with a CORE stock is about 30.5. Forgot to compensate for tyre wear last club day and almost got eaten by a flying EVOIII! Still good enough for 21 lap 5.02 though. Won't make the same mistake this week. Body is the ubiquitous Stratus. Hope this helps. Scotty |
Any particular rubber work better than others?
I have seen ppl go fast on all of the better rubbers (sorex, pits, & takeoff). If you are looking, pits have a broader temp range that makes em a bit easier to use...
Originally posted by Dragonfire I have seen ppl go fast on all of the better rubbers (sorex, pits, & takeoff). If you are looking, pits have a broader temp range that makes em a bit easier to use... Cheers. |
interesting
Hmm...keep it coming
Is the protoform honda accord body bad? I got one of those that i havent used, any feedbacks about these bodies Im using 40f and 37r also had a bit of problem with it, way too much understeer well...that really not a problem but could not be bothered changing :lol: :smile: i am interested in trying 40f 40r or may be 45f and 45r ellegis trued down. |
WRX - Pretty much always guaranteed to run same rear tire, i just change the from from 40 to 37, depending on how much steering you need. i have never tried 45-45 but i would doubt as to its performance.
You also have to keep in mind that a front compund 40, will not provide equivalent grip as a rear compound 40. In practical terms it is equivalent to going up 5 shore in tire. ie 40f-40r equivalent to running 45r-40r. As the front foam has a different composition.
thanks
Besercoe: Gees i thought they would be the same :rolleyes: :weird: thanks heaps im going to give that a try.
| All times are GMT -7. It is currently 02:41 PM. |
