KO propo EX-1 Mars! Problem with servo
hey everyone,
I'm a bit new here but been on rcracer a few years.
I have a kopropo ex1 mars
My problem is that i can't specify to reverse the servo on an actual profile.
I have a tt01 which has a sanwa servo, and my other tt01 has a futaba servo,
The thing i wanted to see if i could do was to have a preset so once i press one profile it will automatically change the direction of the servo
Could this be done?
Would be the same setup for any other EX type wheel. same software etc!
Adrian
Could this be done?
Adrian
All you should have to do is name 1 profile one thing with the servo going one way and make another profile with the servo going the reverse and when you want to swap you just change profiles.
It will tell you in the manual how to set it all up.
Hope this helps
Cheers
Nudge
Hope this helps
Cheers
Nudge
Hi
Contact Robert in the states and they will send you a new one through there shopatron Ko shop.
Here is the link to contact him.
[email protected]
Good luck
Addam
[email protected]
Good luck
Addam
