-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Need some help (https://www.rctech.net/forum/australian-racing/108294-need-some-help.html)
Fallout 04-01-2006 05:14 AM
Need some help
hello
i need some help if anybody could give it too me it be a great help.
I trying to make my own battery pack up but:
thay were in stick form but now i'm trying to change them too side by side
but i just cant get battery bars to stick or stay i'm usesing dean solder and dean battery bar .is it me but when i put solder on the battery it just runs off.
Is there somethink i should do first? any comment would be great
thanks
torps 04-01-2006 05:20 PM
try reading this, good article
http://www.balakracing.com/buildingbatterypacks.htm
MadRacer 04-01-2006 05:53 PM
Use a dreamel with a sanding drum on the end plates of the battery, the problem is that the plates are dirty u need to clean them. You can use a knife and scratch the surface clean.. Make sure the iron is hot enough, the Deans solder needs a hotter iron than normal solder.
