Go Back  R/C Tech Forums > International Forums > Australian Racing
noob to elect needs help >
Old 02-07-2006 | 04:31 AM
Angry noob to elect needs help
hi all ,
i was useing my evader today and went thru 3 battery packs ,used the #1 pack let it cool then put on charge. #2 pack installed after evry thing cool & checked over truck no worries with these two battery packs .pack #1 battery fully charged and everything cool used for ruffly 20 mins or so then started to get sluggish so i knew that the battery was goin flat so i drove the truck over to where i was and turned evrything off truck first then control took strap off and battery out but when i went to unplug i noticed that the positive side of the connector from my esc side was melted together like it had been shorted out .i have Tamiya style plugs so they will only go on one way also i noticed that my ESC was extremely hot but now i will have to do some rewireing i think ..... of anybody can suggest why on my last run was everything so friggin hot (battery,esc & motor)?
please help me out as i am a new comer to electric
P.S.. BATTERY PACK #1 IS *venom racing 1800 nicd power pack
BATTERY PACK #2 IS *team orion ROCKET PACK 2400 NI-CD pack
BATTERY CHARGER IS *ANSMANN energy ACS 67P+ 7.2 - 8.4 v super fast delta-peak charger
i only have thes 2 battery packs
thanks for any advice you can give
pete075 is offline
Old 02-07-2006 | 01:34 PM
The Tamiya style plugs have a higher resistance that other types of plug like deans or corraly connectors. i have melted some together in the past when using a stock motor.
It can also happen when the connector inside the plug is arcing which can cause the plug to get scorched on the inside, i had this happen on a charger i have.
to fix this replace the tampiya style plugs with Deans plugs or some other after market low resistance plug.
you may also want to check to see if the motor is over geared as this will cause the ESC, Motor and battery to over heat. try lowering the gearing ans see if that helps.
Monaro_Racing is offline
Old 02-08-2006 | 02:20 AM
Superkarter's Avatar
Get rid of those tamiya plugs. I melted a pair and it was the best thing i did as it made me change to deans.
Superkarter is offline
