Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
DCX Receiver & Spectra Modulation >
Old 12-20-2005 | 04:19 PM
Default DCX Receiver & Spectra Modulation
Just wondered if the modulation for the Spectra and DCX receiver were PCM or PPM or something else, help?
warndry is offline
Old 12-21-2005 | 04:50 AM
Tres's Avatar
Company Representative
PPM (FM)
Tres is offline
Old 12-21-2005 | 07:44 AM
Another question... the Hitec Spectra module has a PCM/PPM frequency capability on it. Is there any way to get the PCM frequency with the Aggressor CRX? I checked in the CRX manual and couldn't find it mentioned anywhere? I have a Futaba 1024 PCM reciever and can't get my CRX radio to work with it!
warndry is offline
Old 12-21-2005 | 08:32 AM
Tres's Avatar
Sorry, CRX is FM only.
Tres is offline
Old 12-21-2005 | 10:02 AM
I thought the PCM was still FM, is it not? My friend has a 3PK that he runs a spectra from also (FM) but his radio has the ability of changing modulation from PPM to PCM and HRS, aren't all those still under FM? The crystals in the recievers don't need to change between PPM and PCM and they are FM 75mhz crystals!
warndry is offline
Old 12-21-2005 | 10:07 AM
Tres's Avatar
PCM is in part of the encoding of the signal.....
So yes, you are correct.
I should have stated it differently.
However, the CRX does not support PCM, only PPM.
Tres is offline
Old 12-22-2005 | 12:58 PM
Thanks for your help!
warndry is offline
