Digital Servos and BEC
I am planning to run TC on carpet with a 5925 servo. My concern is the power draw the digital 5925 has from the BEC, as your servo manual states:
Make sure you bypass the BEC for stable operation.
How am I to determine the power the servos draw from a BEC system under load? Do I have to bypass BEC? If so can I directly power the servo using a 7.2 volt 3300 battery?
Is the 5925 a FET servo?
